hello
Old May 6, 2014 | 05:15 PM
rednecklawson's Avatar
hello
I have a problem I have a 98.5 dodge it won't start. I have fuel to the injectors I just put a different injector pump injectors and delivery tubes on it and still can't get it to fire.
Old May 6, 2014 | 11:14 PM
SIXSLUG's Avatar
12 valve or 24?
You may get a better response if you Title your thread "injector trouble" or "new injectors, no start" etc.
Old May 7, 2014 | 08:11 AM
patdaly's Avatar
Gotta be a 24 valve if he replaced Injector tubes.
OP, why did you change all of them, upgrade or to try and fix a no start condition?
Old May 7, 2014 | 06:35 PM
I upgraded them trying to fix the no start problem if something upgrade it right but still no start here is what I got air dog 150 to a hot rod pump
To drilled out delivery tube and 150 HP injectors a edge juice with attitude hx40 turbo and double disk clutch so I figured its got to be something electrical but I'm not even getting a puff of smoke
Old May 8, 2014 | 08:51 AM
patdaly's Avatar
Ok, so it wouldn't run prior.
Now, did it die going down the road or just not start one day?
I am not much of a 24V guy, but I have seen more than one case where simply unplugging the edge will get the problem fixed.
Old May 8, 2014 | 09:06 AM
DIESELWRKS's Avatar
still back to codes??? have you pulled codes with a reader. 98.5 key cycle will not work. do you have any codes. I would suggest turning off the edge .
yes please fill in all the who,what and where.
are you talking that you replaced all the parts and it ran but wont now.
or replaced parts and since the replace havent been able to get it started?
etc, etc,
you said you upgraded to fix the no start problem. what exactly was the no start problem. did you pull codes on the old VP that showed the injection pump was bad and then replaced it with the Hot/Rod pump??
hdm48
Feb 12, 2003 07:14 PM
Jan 21, 2003 03:23 PM
Farmall
Dec 20, 2002 05:54 PM
Dec 14, 2002 01:21 AM
Palmetto_kid
Nov 23, 2002 04:54 PM
