Heating Grid & fuel pump Quits
Old Oct 30, 2009 | 06:36 AM
nelogpro's Avatar
Please Help, Heating Grid & L.Pump Quits
Please help, I have had a problem for over a year now, the air Heating grid & elactric fuel pump that used to kick on for a little bit before you start the engine, just quit... when I remove batt term. & reset computer then it will work again, maybe for 5 starts, maybe for 50 starts. could it be the Air temp sensor, or ECM, pretty costly to trial & error part. It starts fine in the summer without, but when cold becomes a problem.
Old Oct 30, 2009 | 09:57 AM
johnh's Avatar
fill out your signature so we will know what truck is having the problem
Old Oct 30, 2009 | 04:13 PM
nelogpro's Avatar
99 3500 24V 4wd dually pickup Sorry I am new, I thought that would show up from my profile
Old Oct 30, 2009 | 10:25 PM
nickg's Avatar
if the grids are not working I'd say test and replace grid relays, if required, or if the ECM is not turning them on wire them up so you can manually control them.
does your wait to start light come on??
fuel pump some times you might not hear it as it could cycle for only .5 of a second, other times it runs for up to 20sec if you bump the key.
Do you have a fuel pressure gauge to verify fuel pressure when truck is running?
Old Oct 31, 2009 | 07:35 AM
nelogpro's Avatar
After Removing Batt cables, everything works fine for a while, Grids heat up. Wait light comes on, lp runs. As most, I have toasted the vp44 with worn out lp, so installes fuel pressure warning sensor. I have considered wiring the grid relays up to push button, but I would like the lp to run also & dont want to do anything that would damage the ECM. You dont think the Air temp sensor could be problem?
diesel4play
13
Feb 16, 2009 11:16 PM
HaulinRoans
Oct 19, 2006 10:34 AM
pakrause
Dec 28, 2005 10:12 AM
ramit98
Sep 25, 2003 09:35 AM
KC
Jan 14, 2003 06:30 AM
