Headlight issue
Old Sep 16, 2009 | 10:21 AM
AK diesel dog's Avatar
Headlight issue
Ok the other evening I'm cruising along and have to turn off the high beams due to an oncoming vehicle, I hit the switch and my headlight turn off completely! I hit the switch again and their back on but still on high! I keep hitting the switch--high beams/off---bach and forth. Finally I get low beams, has anyone else had a similiar experience? Is it a quick fix?
Old Sep 16, 2009 | 06:25 PM
dozer12216's Avatar
Quick fix is turn signal switch or multifunction switch. Same piece.
Old Sep 17, 2009 | 05:05 AM
Royce70's Avatar
Look at your wiring harness first. I had no low beams at all, just day time running lights (canadian) When I was installing my trans gauge (column mount) I found my connector had a wire that was burn't. Apparenly not making proper contact. The connector is very easy to check. Repaired burn't area with a new wire (heavier gauge) and ran the wire into the harness connector seperately, due to the fact old wiring caused a burn't area in the connector body. Nothing that a dremel didn't take care of. Now I'm good to go. Wished I had done this first as opposed to buying a new day time module, thinking that was my problem
Royce
Old Sep 17, 2009 | 08:07 AM
scottsjeeprolet's Avatar
It's the purple wire under the steering column cover. Mine did the same thing, it's from tilting the steering column. The wire came unplugged. It's a little short so i used some RTV to aid it with staying connected.
Old Sep 20, 2009 | 05:58 PM
Hey thanks for the help-all the info will give me a place to start looking. Is getting to the multi-function switch a pain? Pull the steering wheel and there it is, or is there more to it?
Old Sep 20, 2009 | 07:50 PM
No need to pull the wheel. Just take the cover off and it's on the left . Cluster of wires. the Low/high beam wire that was my problem is purple.
Old Sep 21, 2009 | 12:43 AM
Dinner's Avatar
Also sometimes it's as easy as spraying some brake clean/contact cleaner in the switch itself. Kinda got to shoot it where you think the contacts are for high/low switching. Sometimes dust and what not gets on the contacts and makes a crummy connection.
Old Sep 21, 2009 | 01:27 AM
kennyhammond's Avatar
wow thanks my truck does the same thing and i was wandering how hard it would be to fix thanks fr the help also.....
mtdoragary
Nov 7, 2013 08:31 AM
greatwhite
Oct 21, 2006 09:35 PM
NavyChief
Dec 18, 2005 07:52 PM
jlipskoc
Oct 24, 2005 01:16 PM
georgia peach
Mar 2, 2005 06:29 AM
