Head Gaskets???
Old Jan 30, 2008 | 09:20 AM
ramsport59's Avatar
Head Gaskets???
I've been trying to hunt down a Headgasket for my 2001 24v. I need one that is .10 thicker then stock. I'm not going with studs, or have anything fancy done to my rig. She's just a tow rig.
Where do yall recommend to go to pick one up?
Thanks
Rick
Old Jan 30, 2008 | 05:54 PM
dozer12216's Avatar
Your friendly Dodge or Cummins dealers should understand what you want. The machine shop should have source also.
Old Feb 4, 2008 | 04:19 PM
ramsport59's Avatar
Cummins says a 10 over headgasket doesnt exist for a 24v. Help Anyone?
Rick
Old Feb 4, 2008 | 08:30 PM
ScottGregory's Avatar
Did you have the block decked? If I read the manual correctly, you need to regrade the pistons when you do. If the engine is still apart and your pistons are good, I've heard that you can cut that off of the top of the pistons. Pistons should have about 0.024" protrusion iirc.
I am in the process and will get the pistons turned down to maintain a 0.020" protrusion. Using a std head gasket.
Teddy Bear
14
Oct 23, 2006 10:28 AM
ddestruel
Mar 25, 2006 07:07 AM
QuadZillaTruck
Feb 25, 2005 01:52 PM
cummins dsl
Dec 20, 2004 08:33 AM
dsl-nut
24
Apr 14, 2004 10:29 AM
