Having trouble
Old Sep 29, 2006 | 09:45 PM
Black04Ram's Avatar
Exclamation Having trouble
I got a problem putting my truck into a gear( Nv4500 ), i replaced the clutch, pressure plate flywheel, with the sbc con ofe, whenever my truck is not running it goes into a gear yet while its running its hard to put it into a gear.. what advice you guys have?? Thanks.
Old Sep 29, 2006 | 10:33 PM
Jim Dynomite's Avatar
Have you checked the clutch slave? When you do get it in gear does it feel real grabby even when it's fully depressed?
.............Jim
Old Sep 29, 2006 | 10:41 PM
Black04Ram's Avatar
the fluid is prefect, dont really understand what you mean by real grabby when its fully depressed? The clutch grabs great once you do get it in a gear.
Old Sep 29, 2006 | 10:48 PM
graphitecumnz's Avatar
Synchros...
Old Sep 30, 2006 | 08:44 AM
upersleder's Avatar
i would try bleeding the slave cylinder more. make sure all the air is out of the line.
Old Oct 2, 2006 | 07:30 PM
tig's Avatar
tig
Sounds like you're clutch is not engaging far enough. Check slave cylinder and master cylinder.
elirandolph
Jan 23, 2006 11:35 PM
moparman63
Aug 31, 2005 05:44 PM
mr T
Aug 23, 2005 06:57 PM
salty mule
Jan 6, 2004 10:48 AM
Got Smoke?
Sep 8, 2003 09:35 PM
