harmonic vibration
Old Nov 24, 2014 | 03:35 PM
robert78.5's Avatar
harmonic vibration
My truck is developing a slight vibration when engine is around 1600 rpm,, even in neutral sitting still, i put truck in neutral and as i bring rpms up it has a bit of vibration at 1600 , are the balancers prone to go? as far as i know this one is original with over 590000 kms.
Old Nov 24, 2014 | 06:21 PM
Tallguy67's Avatar
Robert, we had this discussion about a month of so ago for some other guy who was having a good vibration based on engine RPM and was not related to road speed. Same symptoms as you. It turned out his harmonic balancer was worn out. So yes, they do wear out.
Old Nov 24, 2014 | 07:57 PM
BigIron70's Avatar
Cummins Guru
Check if index marks are still in alignment.
Old Nov 25, 2014 | 09:03 PM
robert78.5's Avatar
will try and see if i can see marks, I realized that i started feeling it after changing the transmission mount.
Old Nov 26, 2014 | 12:05 PM
cougar's Avatar
Mine does that at idle in neutral. I'll have to check the marks as well.
Old Nov 26, 2014 | 08:39 PM
robert78.5's Avatar
I tried to take some pictures tonight with phone but could not find marks, what i did see was chucks of rubber missing in groove, that might be a sign of it coming apart.
Old Nov 26, 2014 | 08:53 PM
BarryG's Avatar
The marks are hard to see but probably mute at this point as the other condition to look for is bulging or missing rubber
Iirc correctly genos garage sells both the stock one and the fluid damper brand
Old Nov 27, 2014 | 11:31 AM
pind's Avatar
That is a definite sign of it falling apart
Old Nov 27, 2014 | 07:00 PM
DIESELWRKS's Avatar
i posted this awhile back but mine wasn't chunking and by looks fine. but the rubber was hardened on spots and mushy on other spots. so the integrity on the rubber on mine. just like a tire with weather checking and dry rot.
Old Dec 13, 2014 | 04:01 PM
slowflyer2112's Avatar
You should also make sure that your exhaust system isn't touching the frame any where. My down pipe was touching the frame and the vibration in the cab was horrendous from about 1800 to 2200 RPMs
Old Dec 14, 2014 | 08:03 PM
robert78.5's Avatar
Installed new balancer yesterday, really smoothened out the engine.. There were chunks of rubber missing, will try and upload a picture of it.
homermandy
15
Oct 26, 2008 08:52 PM
ASHNBAK
0
Dec 15, 2007 08:03 PM
gatf4
Mar 9, 2005 11:52 PM
lightening ram
Oct 24, 2004 12:51 AM
