Hard Starting
Old Aug 10, 2011 | 05:46 PM
Jaxondad51's Avatar
Hard Starting
Have been having trouble getting started. At first, it just took a second longer, but today, after truck sat for 3 days, it took several minutes.
Any help will be much appreciated.
Old Aug 10, 2011 | 07:40 PM
maxwellp's Avatar
What is it?
Old Aug 11, 2011 | 02:28 PM
Jaxondad51's Avatar
5.9 cummins in an 02' 2500 Quadcab 4x4
Old Aug 11, 2011 | 04:17 PM
10-95's Avatar
Could be anything from a lift pump going bad to the o-rings on the injector tubes.
Try parking with the nose of the truck facing "downhill". Anything?
Hard start when cold or hot???
Lots of variables. Easiest if you can afford it --- take it to the shop. I replaced a lift pump that I probably didn't have to when mine had a hard start problem (always when it sat). I found a guy who KNEW the CTD. He diagnosed the o-ring problem after hearing what I had already done. Then he fixed it at a price I was comfortable with and had it done earlier than promised.
Old Aug 11, 2011 | 04:30 PM
Jaxondad51's Avatar
Thumbs up
Thank you 10-95. Didn't have any problems today. Started fine 6-7 times through the day. gonna let it sit over weekend, see what happens monday.
Old Aug 17, 2011 | 03:02 AM
KATOOM's Avatar
If you've done nothing to the truck recently then its most likely a fuel leak. And that leak is most likely on the return side of the fuel system. As mentioned, parking with the trucks nose pointing downhill will help determine if thats the problem or not.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
L. D. Bryant
Nov 17, 2002 12:18 PM
