Growling noise
Old Mar 17, 2010 | 06:18 AM
sgreen3's Avatar
Growling noise
On my 98 it has a bit of a growling noise from the front end it sounds like. It will do it if you hit a bump. i thought it was a wheel bearing, so i replaced both of them but it still does it sometimes, just not as loud as it was before. Any one have any ideas?
Old Mar 17, 2010 | 07:56 AM
snowjoker's Avatar
Have you checked the front drive shaft ?and your differential oil level ?, even possible that a rear u joint is going, because it will transfer the noise through the whole drive line..
Old Mar 18, 2010 | 06:28 AM
sgreen3's Avatar
I checked the fluid, and it seems there is a noticable amout leaking from the drivers side wheel, I will have to look a little closer at the wheel joints. Thanks
Grit Dog
Nov 26, 2012 12:06 PM
1985cucv
17
Mar 17, 2010 08:47 PM
case310350
Oct 16, 2009 09:55 AM
04ctd
Apr 27, 2005 09:10 AM
petey
Oct 28, 2003 01:48 PM
