grid heater controller
Old Dec 2, 2004 | 09:54 PM
dodgezilla04's Avatar
A buddy just picked up a '98 24v CTD. Problem is the grid heater will not energize. I checked the fuse for it and swapped the relay for the heater and the blower motor. still no power to heater. I checked continuity at the heater, it is good. I checked power to the 2 solenoids(below the drivers side battery) that supply power to the heater, I get 12vdc to one side of the solenoids but nothing out with key on. the rear wire on the solenoids are grounds, good there. the foward wires I can only assume are for incoming 12vdc to activate the solenoid, but no power there. I can hot stick the solenoids and make them energize, so they are still good. The question is, what controls the solenoids and where is it? thanks guys.
Old Dec 2, 2004 | 10:41 PM
farmer dave's Avatar
I am not sure what controls the solenoids, put I had a similar problem with a grid heater not working on a 97. I took it in and they replaces the relays I think, it took care of the problem. Not sure if that is what your problem is but it is worth a check.
Old Dec 2, 2004 | 10:57 PM
torquefan's Avatar
I believe the solenoid windings are grounded by the PCM and I assume powered by the ignition switch. Check all the maxi fuses. Never really seen a problem with the control power circuit before. Make sure the IAT sensor is inputting to the computer properly.
Old Dec 2, 2004 | 11:38 PM
Clint's Avatar
I also have that problem, try unhooking the negative cable from batteries for 30 mins, that fixes mine for awhile. I was also having the TC lockup problem, I put a noise filter in, and so far that has cured both problems, but only on day 3, so a few more days to know for sure. Also if you do find anything I would like to know.
Clint
SpeedyWS6
15
Feb 2, 2011 07:22 PM
Ramrod90
Feb 3, 2009 07:39 AM
taildragger
Dec 4, 2006 10:00 AM
Dodgezilla
Mar 13, 2003 06:14 AM
Chewy
Dec 18, 2002 06:46 PM
