Getting CPS out of block?
Old Nov 2, 2010 | 03:43 PM
dogfish's Avatar
So trying to get my Crankshaft Position Sensor out of the engine block to replace it, it wouldn't budge and I broke the top of it off(cheap plastic crap). Now what's left of it is flush with the side of the block so I don't have any way to grab it from the outside. Is that hole it's pushed into open to the crankcase? Can I drill it out or do I risk sending debris into the crankcase? I also thought maybe I could thread a small screw into the guts of the sensor and use that to pry on it. Anybody have any other handy mechanic tricks to get that thing out of there? I'm suspicious that it failed somewhat catastrophically inside there(melted or cracked apart or something) and is wedged in there good. What makes me think that is there was oil in the top where the sensor connector attaches and on the sensor connector itself. This also may mean I've answered my own question and that hole is in fact open to the crankcase in which case I need to use extreme caution.
Old Nov 2, 2010 | 03:48 PM
MeanGrn's Avatar
had to pull mine hard 2 weeks ago to get out, i wouldnt cut it out but the set screw idea might work, it's not threaded in so get something to pry it out
Old Nov 3, 2010 | 06:29 AM
dogfish's Avatar
Thanks I'll keep working at it Anyone else have any ideas?
Old Nov 3, 2010 | 07:52 AM
high bid's Avatar
not trying to be a smarty pants but you did remove the screw/bolt that holds the cps in correct? When I replaced mine I twisted it left to right and it came out. There is a small o-ring gasket which may have dried up, try spraying some lube on it to loosen things up. Hope this helps.
Old Nov 3, 2010 | 09:30 AM
dogfish's Avatar
Thanks Guys Yes I did remove the bolt/bracket but I'll try some PB penetrating lube too
Old Nov 3, 2010 | 09:40 AM
johnh's Avatar
what year???
Old Nov 3, 2010 | 01:10 PM
Junk Man's Avatar
The CKP has an O-ring which helps seal it and make it difficult to remove. The CKP turns in the o-ring. Keep twisting. It eventually comes out. Try prying with a small screwdriver. Get the screwdriver to catch & you can lever the CKP out (perhaps). You'll not break one off again.
jesussaves
Jul 18, 2009 05:45 PM
John In NC
Oct 22, 2005 09:14 AM
Dodgezilla
Jul 17, 2004 05:24 AM
z1bigtom
May 28, 2004 05:02 PM
BigBlackDodge
Mar 16, 2003 09:04 AM
