Generate codes
Old Dec 19, 2006 | 02:39 PM
swordfish's Avatar
Generate codes
I see all the time you guys talking about codes. I asked my brother about this who used to be an auto tech and he said after 1998 the gov. mandated the OBD gen 2 system and you couldn't get codes anymore by using jumpers or doing the ignition trick. how are you guys getting your codes?
Swordfish
Old Dec 19, 2006 | 02:43 PM
dodgezilla04's Avatar
chrysler vehicles are nice. turn the key on and off 3 times, leaving it to ON. the odometer will display the codes starting with a p. this is to on, not crank
example. p0191
Old Dec 19, 2006 | 03:03 PM
swordfish's Avatar
Dodgezilla...thank you very much!
Old Dec 19, 2006 | 03:08 PM
Thumbs up
you betcha
Old Dec 19, 2006 | 03:23 PM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Thank you Dodgezilla04
Old Dec 19, 2006 | 03:29 PM
PourinDiesel's Avatar
I dont think that works on Dodge Cummins pickups until model year 00 or 01.
I know my 99 would not display codes.
Old Dec 19, 2006 | 04:54 PM
CTD NUT's Avatar
Swordfish
That is simply not true.....in fact, quite the opposite on our CTD's. Reading DTC's in the odometer display didn't start until the 00 model year on our trucks. Follow Dodgezilla04's instructions and the DTC's will be displayed if any are present.
Old Dec 19, 2006 | 05:50 PM
phox_mulder's Avatar
Won't work on either of yours though.
2000 on up for the odometer reading,
pre 1998 flashed the check engine light a certain number of times.
1998 and 1999 got left out entirely.
(maybe the 98 12 valves still did the CEL flash thingy)
phox
Old Dec 19, 2006 | 06:43 PM
johnh's Avatar
example. p0191
not all codes will show up, some will only show with a scanner, at least on my truck
Old Dec 19, 2006 | 06:50 PM
CTD NUT's Avatar
Very true....
Old Dec 20, 2006 | 07:30 PM
Carolinablue's Avatar
Thumbs up
Works great on my 2001 Dodge Cummins.
Thanks for the tip Dodgezilla04.
Old Dec 21, 2006 | 06:21 AM
phox
Phox, I am very aware of that,I already knew about all of that . I was messin with DDZ04, thanking him for helping someone out.
Old Dec 21, 2006 | 07:21 AM
Shovelhead's Avatar
Administrator / Scooter Bum
There are "tricks" that vary by manufacturer to read the stored codes.
I can pull codes from both my Wifey's Toyota LandCruiser and my fuel injected Harley.
Old Dec 21, 2006 | 06:00 PM
Gotcha.
As long as you know it won't work on yours.
(as well as the newb's with 98/99's reading this thread)
phox
Old Dec 22, 2006 | 05:16 AM
Phox. Thank you
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tobyw
Sep 16, 2004 10:07 AM
