gears
Old Aug 13, 2005 | 08:09 AM
nubby3's Avatar
gears
Where is the best place to get gears.I want to change from 4.10 to 3.54.
Fuel milage 16 empty & 9 towing 30 ft. travel trailer.Trying to get 10 or 11 towing.
2001 3500,quad cab,auto,edge ez,4" magnaflow exhaust,cold air filter.
Old Aug 13, 2005 | 09:09 AM
J BODY's Avatar
Depending on your trailer weight you may or may not help your mileage towing. My truck was born with 4.10's and I swapped them out for the 3.55. Drivability empty is alot better and our heaviest trailer only comes in at around 8500 so keeping the stock tire size it does the job. From what I've experienced a 3.7 gear would have been nice.
http://www.ring-pinion.com/content/p...sp?vid=1&pid=4
Old Aug 13, 2005 | 02:21 PM
thumper 549's Avatar
you may want to go to a overdrive unit and have the beast of both worlds
Old Aug 13, 2005 | 07:57 PM
newriverSpecon's Avatar
Way to go if you can afford it(What I would like to have done). Or just put the money in the engine and gear to 3.54 (what I am doing).
Randy
Old Aug 15, 2005 | 07:23 PM
Ripper /Rattler's Avatar
Check out a Gear Vendor overdrive unit for sure . Make your 5 spd a 10 , you would have a overdrive in all 5 forward and 2 reverse. It is a plantary gear set installed after the trans . nice and quiet with push button operation My friend just did one him self for like $1600.00 usd . If you look into it that is not much more than rebilding both front and rear diffs (the gear ratios must match) Im told they handle up to 1000 H.P. and 1200 ftlbs torque.
they do make gear vendor over drives for auto transmissions and 6 speeds aswell.
good day
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
