gear ratio
Old Mar 17, 2005 | 03:39 PM
Lenn's Avatar
Question gear ratio
Has any one changed their gear ratio? I have a 2001 4x4 with auto and a 355 limited slip. I would like a 410. You would have to change front and rear right. About what is the cost of doing a switch?
Old Mar 17, 2005 | 03:50 PM
Mcmopar's Avatar
Yes you should change both, if you didn't and ever put it in 4X4 things would break!! Cost is totally dependant on what you will get charged for labor. The gears are about 250 for the front Dana 60, the rear is a Dana 70 or 80, the cost for those gears are about 270 for the Dana 70 and about 400.00 for the 80. Then you will need the bearings etc, about 200 per axle. You can probably find a rearend guy who will do the swap for around 250 per axle. So you are looking at about 1400.00. Ouch. I would try to find someone who wants your 3.54's and trade
Old Mar 17, 2005 | 04:29 PM
bmoeller's Avatar
Unless I'm mistaken, you will need to change the carriers also.
Old Mar 17, 2005 | 04:34 PM
Mcmopar's Avatar
The 60 will go 4.10 or 3.54, I think the 70 is the same, the 80??
Old Mar 17, 2005 | 06:01 PM
bluebull's Avatar
I know the 80 you will have to change carrier. Parts for changing I was just recently quoted $1,200.00, Labor is dependent on who does the work. Four years ago I was quoted $2,600.00 at the dealer. I used the money to buy power upgrades instead.
Rearends can be very touchy, get it wrong and you wish you would never have messed with it.
design
32
Jun 23, 2003 10:07 PM
mbw
Mar 5, 2003 05:38 AM
Garz
Feb 3, 2003 09:08 AM
Cutthroat
Jan 8, 2003 09:37 AM
accordionjohn
Oct 7, 2002 12:54 PM
