fuel work=codes?
Old Mar 4, 2005 | 11:08 PM
upersleder's Avatar
fuel work=codes?
i did some fuel line work today, installed new banjos, took off my fuel filter changed it and added stuff to hook up my FP gage tomorrow, after putting it together i bumped the starter and ran the pum thru its cycle three times, made sure there was fuel in the filter and tried to start it, it was hard starting, i ran the pump a couple more times and it started up. after that i checked the codes and it threw two faults, injection pump timing and some other fuel code, i erased them and have had no problems since, i put about 80 miles on tonight. is this normal? did i hurt something? hope not. i will check again tomorrow for codes, but just want someone elses opinion. THANKS
steve
Old Mar 4, 2005 | 11:14 PM
tool's Avatar
I've heard that clogged filters and such can throw a pump code, so I guess changing the filter would sort of be a similar condition. I hope you are that lucky and your pump isn't dying.
Old Mar 4, 2005 | 11:20 PM
upersleder's Avatar
the filter was changed about 15,000 miles ago. i hope it wasnt clogged, there was a small amount of sandy dirt in the bottom of the housing, i just took it out and funneled it into the fuel lin......er no i cleaned it out.
gages tomorrow, so we can monitor the sitcheeashun!
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
