Fuel/Water Separator Drain
Old Aug 24, 2009 | 12:37 PM
DryCreek's Avatar
I looked around, but didn't see any thread about the drain valve assembly leaking on the fuel/water separator. Is this fairly common? My '01 was really leaking the other day - about one drop per second. The fact that I was heading home pulling the camper compounded the worry-factor and made it an unpleasant drive. I made it 90 miles home, and the wife was following in her truck (full load of cattle) in case things didn't go as well as we hoped for.
The leak was up along the valve stem (shaft) as well as from the drain port itself. I cycled the drain and the leak only got worse from the shaft, and slowed a little from the drain port. Once I got the truck home I removed the drain assembly from the separator and disassembled it. I found a piece of trash was fouling the seat, and the stem seal o-ring was worn. In fact, all of the seals were worn. I couldn't find a new drain valve assembly listed on the auto parts websites, so I just went in and bought some generic o-rings from their "big red box". I couldn't determine if the o-rings were Buna-N, Viton, or any other composition. I hope that they are fuel resistant! I will know in about a week or so I guess.
Is there a rebuild kit for the drain assembly? I reckon that some day my wife's truck will need the same repair. Mine only has 180K on it (hers just turned 60K).
Dry Creek
Last edited by DryCreek; Aug 24, 2009 at 12:39 PM. Reason: spelling! Shaft, not Shat!
Old Aug 24, 2009 | 03:11 PM
J BODY's Avatar
That's the very reason I never touch mine.
Old Aug 24, 2009 | 03:26 PM
nkennedy's Avatar
I used a generic viton O rigs. They are fuel compatable.
Old Aug 24, 2009 | 04:28 PM
Dr. Evil's Avatar
I just greased mine up with synthetic grease and all was well again.
Old Aug 31, 2009 | 02:43 PM
DryCreek's Avatar
OK, status report - one week later (plus a few days) and the O-Rings haven't turned into a pile of goo.
Old Aug 31, 2009 | 03:54 PM
PaulDaisy's Avatar
Buna-N is diesel compatible, it will be fine.
Thundercraft
Jan 21, 2008 09:40 PM
Jeeptug
Apr 11, 2007 11:49 PM
67HotRod
Jun 13, 2005 08:01 AM
DODGE4X4
Jul 26, 2004 10:17 AM
Hoss
14
Jun 16, 2003 08:51 AM
