Fuel Temp
Old Feb 21, 2006 | 11:17 PM
who's ram's Avatar
Fuel Temp
I have a question. Does the cold make your fuel pressure drop or should I be looking at some thing else? I get 13psi at idle and 7-9 normal driving and 4-5 wot. I notice that some time when cold at idle it will go to 1-2psi for a second and then it is right back up.
I also keep getting a crank shaft sensor code when it is cold would that be a cold thing or do I need to change it.
Last edited by who's ram; Feb 21, 2006 at 11:44 PM. Reason: More information added
Old Feb 21, 2006 | 11:51 PM
rebal's Avatar
it sounds like your lift pump is no good mine was doing the same thing, a new cummins pump cured that! cant help with the sensor sorry might check for clean and tight connections at the sensor its self
Old Feb 21, 2006 | 11:58 PM
who's ram's Avatar
Thanks, I thought that might be the case i just hoped that was not it. I just got some gauges and now i am kind of paranoid.
Tree DR
15
Mar 9, 2008 05:50 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
jaconst
Jun 25, 2006 10:23 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
