fuel psi
Old Mar 13, 2006 | 01:19 PM
Brad02ctd's Avatar
fuel psi
is to much fuel psi on a 24v. bad for the Inj pump. im running like 22-23 psi with the FASS. I went through 3 lift pumps before putting the fass on, had the computer scanned and its throwing P0216 out.
Old Mar 13, 2006 | 01:22 PM
Geico266's Avatar
The only thing I've read is that high fuel PSI will cause hard starting. If you are starting okay I guess you are good to go.
The 0216 is the IP death code though. That is not a good sign. I'd be looking at a replacement ASAP. Seems like you can run them for a month or so then they die after you get the death code.
Old Mar 13, 2006 | 01:33 PM
Brad02ctd's Avatar
alright thanks, i dont have any trouble starting it. thats what ive heard is not to much longer after it throws that code it dies. the truck has 85k miles on it so im just hoping it quits soon so i dont have to pay for one.
Old Mar 13, 2006 | 02:32 PM
piperca's Avatar
Are you getting any symptoms, like dead pedal or surging? Mine threw the P0216 and I drove it for several months without it dying on me. I would only experience problems at highway speeds.
Old Mar 13, 2006 | 02:46 PM
Brad02ctd's Avatar
yea i have had a dead pedal on several occasions. but i have problems with the tranny also it sometimes goes into OD at like 15 mph so i hit the go pedal and there is just no power until i pull it into 2nd gear. it has not happened enough for me to figure out which problem is which.
Old Mar 13, 2006 | 02:50 PM
yamroamer's Avatar
[QUOTE=Brad02ctd]is to much fuel psi on a 24v. bad for the Inj pump.
I hope not,just fitted a pusher pump.
!`m running 29psi at idle and 25 psi on the move.
Old Mar 13, 2006 | 02:59 PM
Brad02ctd's Avatar
well i wouldnt think so but I just thought it was suspicious that I put my FASS on 4 months ago and now I have that code in there. But if it does I suppose you'll find out the hard way.
Old Mar 13, 2006 | 03:51 PM
piperca's Avatar
Sounds very much like your VP. Join the club, I just replaced mine last weekend!
38 Cigarette
16
Aug 28, 2015 11:27 PM
schamran
Dec 14, 2009 08:20 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
