Fuel Pressure Question
Old Feb 21, 2006 | 10:28 PM
solaman70592's Avatar
01 4x4 Quad
I replaced my LP yesterday, put in an OEM Carter,pressures are better 15-17psi on key cycle, and 7-10 on cranking. Truck don't start, (have reman VP-44 on the way). Can anyone tell me if there should be pressure on the system after the LP pump shuts off. I replaced the overflow valve in the VP because it was not holding pressure. 70,097 miles, Adding a Vulcan Relocation Kit (Geno's Garage) and a Westech Fuel PSI Guage (Geno's Garage).
Old Feb 21, 2006 | 11:09 PM
piperca's Avatar
No pressure registers when the LP is not running.
Old Feb 28, 2006 | 03:38 PM
Thanks for the info, as i had read a thread where someone said there was a check valve in the tank and if this was true then it should hold some pressure which it was not. I could not find anything in the factory manual on this either.
Thanks once again
dodgeguy71
17
Jan 19, 2012 12:52 AM
jimbo486
May 5, 2010 06:44 PM
OldDodgeOwner
Feb 13, 2009 05:13 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
