Fuel Pressure Question
Old Sep 5, 2009 | 09:11 AM
Geico266's Avatar
I've been having issues with fluctuating fuel pressure on start up ever since I installed a new VP44. Not all the time, but a few times a day I will start the truck and the FP will be around 10 PSI (normal is 16 PSI). If I put the truck in drive it with the FP at 10 PSI it will die. If I put the truck in neutral first the fuel pressure immediately comes back up to 16 PSI and then I can put it in drive and no stalling.
What would cause the fuel pressure to change just by putting it in neutral?
FASS HVLP pump.
Ideas?
Old Sep 5, 2009 | 01:52 PM
Fishin2Deep4U's Avatar
Really, should not be anything to cause that. Could be something with a ground fault I guess.
Dave
Old Sep 5, 2009 | 06:24 PM
Geico266's Avatar
Dave
I'm scratching my head too. I can't figure out how putting the truck in neutral would change fuel pressure.
Old Sep 6, 2009 | 09:33 AM
triker888's Avatar
Check the pressure coming from the fuel filter. Had a similar problem with my FASS, dual filter, 150/150. The first filter visually checked out, but something in it wasn't allowing the fuel to flow while meeting the demands of having it in gear. Do a fuel flow check.
Old Sep 6, 2009 | 03:06 PM
j-fox's Avatar
Electrical or mechanical guage?
I've seen electric one thet were very sensitive to voltage.
dodgeguy71
17
Jan 19, 2012 12:52 AM
jimbo486
May 5, 2010 06:44 PM
OldDodgeOwner
Feb 13, 2009 05:13 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
