Fuel pressure Question
Old Apr 11, 2007 | 11:14 AM
Jerrod's Avatar
I just put a fuel pressure idiot light on, set at 5 lbs. Going around town it never comes on, but put a load on it or WOT and it comes on. I guess i need a new lift pump. But i was wondering how to make a mechanical gauge to to put on there so i can check the acual fuel pressure.
Old Apr 11, 2007 | 03:03 PM
fade94's Avatar
You can get a mechanical test guage that goes on the schrader valve. But, you can get a mechanical gauge and mount it for about $50 total.
Also, put something in your sig about where your at in Texas. LOTS of people on here in TX that can help you out with just about anything.
Old Apr 11, 2007 | 05:18 PM
Jerrod's Avatar
Im here in Chillicothe, Tx
Old Apr 13, 2007 | 09:35 PM
mdobsch's Avatar
I just had the "in tank" pump installed under warranty. Now I only have about 7 psi at idle and I can pull he down to about 3 psi at wot. I guess as long as I have some pressure things are ok. Sure is hard to get used to seeing that low of a reading though, after having 14 on idle on the old stock pump.
Old Apr 13, 2007 | 09:53 PM
crobtex's Avatar
Everywhere but there!
Just kidding......
Old Apr 13, 2007 | 09:58 PM
crobtex's Avatar
Check some of the vendors in the "Links" above and get you a GOOD mechanical FP gage. Also, it wouldn't hurt to get one of the "big" line kits.
Also, it sounds like your fuel pump is about gone. Don't chance it.......Go to Cummins and get the "campaign pump" or some other aftermarket pump.
Do a search for "fuel pump" and you can get a lot of options.
Old Apr 16, 2007 | 09:23 AM
Jerrod's Avatar
I installed the big dog fuel kit with walbro pump on Friday night. Now i have 18 lbs at idle and 15 at WOT
Old Apr 16, 2007 | 09:30 AM
Dr. Evil's Avatar
Uh, no...you might want to install a bigline kit (with drawstraw) and put a pump down on the framerail. Or do some other type of fuel system upgrade...Walbro, Fass, Fass 2, Airdog, RASP, etc.
These guys have everything you need:
www.vulcanperformance.com
Save your injector pump....
dodgeguy71
17
Jan 19, 2012 12:52 AM
jimbo486
May 5, 2010 06:44 PM
OldDodgeOwner
Feb 13, 2009 05:13 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
