Fuel Pressure question
I was just wondering how long you’ve run the Campaign pump back at the frame. I’ve read that no matter where you put them, these pumps still loose pressure and go bad. I'm thinking of adding the Vulcan Big line kit with my Campaign pump, and if it doesn't last then get the Walbro.
Oh just to clarify, Geno’s Garage sells both the cheaper ($70) relocation kit with the 3/8” lines, and the full Vulcan Big line kit ($130) with 1/2” lines. I did notice that on Geno’s website they list the 1/2” hose (a blue hose) to be 250psi, but if you go directly to the Vulcan website they list the 1/2” hose (a black hose) to be 50psi, where did you get your kit, and are your hoses blue or black, are they rated for 250 or 50psi?
I got mine from...
www.vulcanperformance.com
More inoformation at... http://www.frontiernet.net/~mopar197...paign_pump.htm
Compare stock 6mm ID fuel line to Vulcan's Big Line Kit (1/2" ID line)
Yes I got to admit the Carter Campaign Pump is a twin of the factory OEM pump but at $50 buck its a lot cheaper to replace compared to OEM at about $209 bucks or even worse yet think or FASS or Walbro kit being as high as $300 for pumps...
At least the I can get the campaign pump locally at my Cummins shop in Grangeville, Id which is 60 miles away...
dodgeguy71
17
Jan 19, 2012 12:52 AM
OldDodgeOwner
Feb 13, 2009 05:13 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
