Fuel pressure problems
Old Feb 12, 2006 | 08:50 AM
DEEREHAULER's Avatar
I think my lift pump is bad again, but what is going on? At idle or when you let off throttle pressure is at 5-7 psi, if you step on it the pressure jumps to 11-12 psi. WOT is about 10. Pressure will jump up and down at idle. The truck has 162k on it and this is the third lift pump. Is there any sort of a relief on the return side of vp that could be acting up?
Old Feb 12, 2006 | 08:56 AM
99 cummins's Avatar
Check out this thread. https://www.dieseltruckresource.com/...ad.php?t=91935
Old Feb 12, 2006 | 09:46 AM
jaxworks's Avatar
move LP to frame
The lift pump can be moved to the frame below the tank using the bracket off the engine. This puts gravity feed to the LP at all times and with any amount of fuel in the tank.
dodgeguy71
17
Jan 19, 2012 12:52 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
JEric
Jul 24, 2005 10:18 PM
mrpiano458nte
Oct 3, 2004 08:21 PM
FastSS
Jul 19, 2004 12:16 PM
