Fuel Pressure Gauge/Isolator install
Old Nov 6, 2006 | 11:23 PM
redassag00's Avatar
Hi Guys, I ordered an ISSPRO fuel Pressure gauge with an isolator from Diesel Performance PArts.
The Isolator instructions tell me I need to fill the gauge and isolator with 'fluid'
What are they talking about? Water? Should I fill the 'gauge' side of the isolator and the gauge itself with water??
Old Nov 7, 2006 | 12:21 AM
1-5-3-6-2-4's Avatar
glycerin if anything. liquid filled guages are glycerin
Old Nov 7, 2006 | 01:47 AM
Baggy's Avatar
Yup, my autometer instructions says you can fill with antifreeze should you spill any.
Old Nov 7, 2006 | 02:09 AM
Rauschbo's Avatar
- check around this website, you will find that probably 98% of the people do NOT use the isolator due to premature failures....
Old Nov 7, 2006 | 02:13 AM
this is the fuel guage going into my truck to replace the POS thats in there. can't see it in the pic but theres a small rubber plug in the 12oclock position just behind the bezel. it doubles as a vent and fill port.
Old Nov 7, 2006 | 08:44 AM
mbfarms's Avatar
If you use a needle valve with the Isolator, you will have very little problems. At least that is what I have experienced. The isolator needs to be filled with 50/50 antifreeze. 50% water, 50% antifreeze. This allows the antifreeze to be a little thinner and work the gauge better.
Old Nov 7, 2006 | 09:44 AM
rharveysr's Avatar
Given a little time...you will remove the isolator. They are nothing but headaches. Needle valve to stop the lift pump pulsation and your good to go. Tried a number of isolators and now they are sitting in my tool box taking up space...
Rick
Dusty Ratcliff
13
Feb 14, 2007 06:40 PM
53 willys
65
Jan 13, 2007 01:38 PM
xp8103
Sep 26, 2006 01:55 PM
truckjunkie
Oct 10, 2005 08:43 AM
gaRam
17
Sep 6, 2004 08:39 PM
