Fuel pressure drop with grid heater
Old Feb 20, 2007 | 09:02 AM
farmer dave's Avatar
Is there anyone else who notices that their fuel pressure drops when the grid heater kicks in? It only drops about 1-2 psi. I thought that is might be the filters but I changed them. What else could it be? Gauge is accurate and post filter.
Old Feb 20, 2007 | 09:18 AM
Doug_TX's Avatar
I've noticed that my FP comes up several psi once the engine is up to a good operating temp. Makes me wonder if the grid heaters are pulling enough juice to slow the LP down. Anyone know when the grid heaters cut off completely?
Old Feb 20, 2007 | 09:43 AM
jiMMyCTD's Avatar
do you have an electric or manual gauge?
I thought the heaters stopped at 60 *F or anything over 20-25mph....
Old Feb 20, 2007 | 09:58 AM
dssimecek's Avatar
Yes, I have noticed the FP drop with the volt meter when the grid heaters cycle on. It is an eletric gauge.
Old Feb 20, 2007 | 10:04 AM
crobtex's Avatar
Maybe a function of the ECM/PCM? When the heater comes on, the engine calls for more power, thus the fuel pressure drops. Just like slight acceleration will cause the fp to drop a little.
Old Feb 20, 2007 | 10:06 AM
nitrousn's Avatar
Normal because the batterys voltage drop due to the 200 amp load the grid heaters take.
Old Feb 20, 2007 | 11:20 AM
VADSLRAM's Avatar
I haven't noticed a pressure drop but I put in a FASS pump that has a definite distinctive sound and it changes as the grids cycle.
If you are losing pressure then your pump is probably at capacity so keep an eye on it, that or your batteries are on the way out.
Old Feb 20, 2007 | 01:01 PM
I have a mechanical gauge. I thought that it might have something to do with the batteries but the cold weather has put them to the test. I know that my batteries are still good if they can start in -20 w/o the windchill.
Old Feb 20, 2007 | 01:10 PM
Lama's Avatar
My FP drops 1-2psi when the heater grids cycle, and my lights dim, and my dash dims, etc. Seems normal.
Old Feb 20, 2007 | 01:37 PM
I just wanted to make sure that it wasn't the pump gong bad or something.
Old Feb 20, 2007 | 01:57 PM
RowJ's Avatar
Ditto, the gearotor definately slows a bit and changes pitch...but no loss of FP!
RJ
Old Feb 20, 2007 | 02:25 PM
bnold's Avatar
I notice a drop of a couple psi from 25 to about 23 when the grid heaters are cycling. perfectly normal and to be expected when there is a 200 amp draw on the batteries... less voltage to the fuel pump less = pump speed= less pressure. some pumps will not notice this if they have automatic returns or bypasses... even though the pump is still spinning slower and pushing less fuel when the grid headers are on the pump is just going to bypass less fuel and show a constant pressure on the gauge... no big deal, like others have said normal
Old Feb 21, 2007 | 06:16 PM
Diesel-Dan's Avatar
https://www.dieseltruckresource.com/...ad.php?t=57485
Some trucks are more noticable than others......
The grid heater only works when IAT temps are below a certian degree....like 50*F or something like that. And they cut off over 20 MPH for some reason....guess they figure EGT will be high enough to take over.
I wouldnt worry about it. As long as the pressure comes back up when the heaters are off....you are fine....
Might not hurt to load test the batts and check the Alt for diode funciton though.....most NAPA's and such have a high end batt/alt tester that work pretty good...just make sure they test one at a time!
SpeedyWS6
15
Feb 2, 2011 07:22 PM
Ramrod90
Feb 3, 2009 07:39 AM
rollie
Jan 23, 2007 09:51 AM
taildragger
Dec 4, 2006 10:00 AM
Mopar1973man
Sep 13, 2005 08:24 AM
