Fuel Pressure Drop
Old Apr 15, 2004 | 02:35 PM
dodgediesel4x4's Avatar
Fuel Pressure Drop
OK, some time between yesterday and today, my fuel pressure at idle went from 15 psi to 13 psi and from 8 psi to 5 psi at WOT. The lift pump was replaced a week ago, along with the fuel filter. I checked for leaks and everything looked good. Is it just time to suck it up and get a high flow kit from Rod? Any ideas guys??
Old Apr 15, 2004 | 02:43 PM
Awww crap, I wasn't even paying attention to where I posted this, haha. I'll be expecting the move shortly!!
P.S. It didn't throw any codes either.
Old Apr 15, 2004 | 03:15 PM
MCummings's Avatar
Hey,
Did you fill up where you normally do?
Sounds like you may have gotten a bad load of fuel. Check your Fuel Filter. www.Genosgarage.com will have cheap filters.
If not, then, you might have gotten a bad pump . It's been known to happen.
Merrick
Old Apr 15, 2004 | 03:56 PM
BigBlue's Avatar
My replacement was spitting out 13 at idle and 6 at WOT straight from the shelf. I had a holley black on mine less than a week later.
Old Apr 15, 2004 | 06:50 PM
Haven't fueled up in over 2 weeks, still the same fuel as it was when I was gettin 15. I'll call up the dealer and see what they have to say about the bad pump situation. Thanks guys.
Old Apr 15, 2004 | 08:02 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Make sure the wire connection terminals at the plug are clean and give'em a little dab of dielectric grease to prevent future corrosion.
Ed
Old Apr 16, 2004 | 09:00 AM
RowJ's Avatar
Agree with Shovelhead. Check your connections! Shouldn't need Max Fuel Flow System at your HP but it is a GREAT addition! Rod's Mod solved all my pressure problems: was considering a FASS but not anymore. Can't pull below 9-10 psi no matter what I do.
Ron R
Sep 16, 2008 11:09 AM
D2 Cat
Nov 27, 2006 09:06 PM
darrenG
Jun 28, 2005 07:43 AM
Dieselholic
Dec 2, 2004 11:29 AM
KATOOM
Oct 22, 2004 11:33 PM
