Fuel line leaking
Old Sep 21, 2012 | 07:16 PM
NE frmhnd's Avatar
Fuel line leaking
How do you get this fuel line to not break?
It runs between a banjo fitting (broken off) on the side of the VP44 and an elbow back alongside the motor. It was leaking when the pump went out a short while ago, started leaking again so we got a new one. When I took the bolt out of the banjo fitting, it snapped back a little bit, wasn't lined up properly. When we put the new one on, I bent the line til I could stick the banjo bolt in, spin it, and it screwed right in. It ran a few days and when it went in for tires yesterday, when it was picked up there was a note on the seat about it leaking fuel (again).
Any chance at all it could be replaced with a hydraulic hose?
Old Sep 22, 2012 | 11:05 AM
SIXSLUG's Avatar
Sounds like it isn't shaped correctly.
Do you have access to a tubing bender?
I believe the aftermarket fuel line upgrades are fuel rated rubber with nylon weave reinforcement.
Others while post up...
Old Sep 22, 2012 | 08:42 PM
NE frmhnd's Avatar
This is only the second time it's broke, I was mistaken, the first time it was the line behind it. Is there supposed to be a support of any sort on it? The dealer had to have it off to do the pump.
I did take some of the bend out of the one right under the pump. We started the line in back, and the banjo bolt spun right into the hole, snugged it down before tightening the rear fitting. It was probably half a hole or more off when we slid it in the first time.
Old Sep 22, 2012 | 09:58 PM
SIXSLUG's Avatar
I would have to look at mine to see about any support brackets, the engine is a real shaker so I imagine there may be some sort of reinforcing hardware on it.
Old Sep 23, 2012 | 09:53 PM
NE frmhnd's Avatar
There were none on this one. It looks like the only place there could be one is behind the fuel filter.
txasylum
Mar 22, 2008 02:47 PM
adidasman23
14
Nov 13, 2006 01:14 PM
mr T
Sep 1, 2006 05:41 PM
99 cummins
Sep 30, 2005 02:15 AM
CCOUGHRAN
Mar 24, 2005 09:42 AM
