front tires wore out
Old Feb 22, 2006 | 05:04 PM
farmboy1973's Avatar
99 Dodge dulley Have had two sets of front tires only have 17K miles on them,(both sets) but the outside of them are wore out, but the inside and middle look brand new. Ran 60lb of air in front ball joints are tight, tow-in is set correctly, have checked twice, allienment has been checked twice, tie rods are tight, so can anyone help me with my problem?
Thanks
Old Feb 22, 2006 | 05:18 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Are you using D or E load rated tires?
I've had Ds wear very badly on the edges due to the weaker sidewalls "rolling-over" (flexing) on turns.
Even when run over recommended Air Pressures, the structure of the tires couldn't support the weight of the Cummins, (and my agressive exit ramp speeds)
Old Feb 22, 2006 | 05:35 PM
they are E's but I do take turn to fast!
Old Feb 22, 2006 | 05:40 PM
I also have a 99 2500 diesel that Irun D's on no problem on it ( but my wife drives it)
Old Feb 22, 2006 | 06:31 PM
Shovelhead's Avatar
Duallys corner like 7,000 pound Porsches.
I'm running Es now and still seeing some wear on the outside edges.
But these are Cooper SRM II tires that are 2 1/2 years old.
They seem to wear much better than the D rated Cavalier brand junk I put on last time.
Old Feb 22, 2006 | 07:00 PM
well I'm going to buy some for the front it's just a farm truck don't want to spend to much on tires.I only put 30000 miles in 4 year (but hard miles) the truck as 158000 miles
kell
Sep 5, 2011 07:49 AM
corn binder
Dec 10, 2010 12:03 PM
Oilguy
Oct 7, 2007 10:32 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Bobcat698
14
Aug 23, 2005 09:57 AM
