Front end troubles
Old Apr 14, 2010 | 12:37 PM
maroonbeast06's Avatar
Angry Front end troubles
ok so i have had stupid 315 tires on my truck and i have switched back to a 265 size highway tire my problem that i am having now is that the front end hits the bump stops every time i go through a little dip or if i go over a small speed bump. i have been looking to upgrade my shocks or add something to the spring to help it also i not a typical kid that goes blowing through speed bumps and dip i respect my truck and take it easy on her any help is greatly appreciated ive been looking for 4hrs now.
2001 Dodge ram 2500 ext cab, ctd Fass 150/150 hrvp44 diablo power puck for fun more goodies to come.
Old Apr 16, 2010 | 10:30 PM
SIXSLUG's Avatar
Sounds like you need shocks, or need to tighten the lower shock bolts. You may also have egged out the control arm bushings and the larger tires were damping the effect.
I thought I was hitting the stops after my 2" levelling kit but found the drivers side shock bolt wasn't tight enough.
If it is your shocks the truck should continue to bounce a few times after each bump. If it settles out after 1 hit I'd bet its something else.
Old Apr 17, 2010 | 12:12 PM
Hodge's Avatar
It is going to take a huge hit to bottom out on the bumpstops- it has to be something else.
1999blackcloud
Jan 26, 2010 08:52 AM
thedude04
Jul 14, 2006 01:52 PM
blackdiesel
Aug 27, 2005 04:58 PM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
