Front DIff Cover Problems
Old Jun 7, 2006 | 06:46 PM
jimmy_jgr's Avatar
Hello Guys~
I've recieved alot of good info on this site about my diesel truck and appriecieate all the discussion and enjoy researching and looking at pictures, But I now have a problem of my own. I have followed all of my maintenance schedule recommendations to the t since I bought my truck in 2002 and one of them was changing differential fluids, all has gone well except the front differential cover has leaked and been re-sealed by the dealer 4 times. This seems to be a cronic problem and the dealer only does the same thing over and over providing no permanant fix, I researched the topic and have found no similar issues. Is there any alternative so that I can have a leak free truck?? and dont have to continually check the fluid level so I can drive? Thanks in advance for the input!!
Have a Great Day
Old Jun 7, 2006 | 09:31 PM
nitrousn's Avatar
Make sure you are using the right rtv silicone and that it is compatible with the type of gear oil you are using. I used the mopar orange or red as it is designed for synthetic gear oils. If you are using synthetic oil and the other sealants they can weep. Mine leaked but i also had rubbed a rock so that might of been some of the problem.
Fill out your sig so we know what kind of truck you have.
Old Jun 8, 2006 | 01:15 PM
Stormin_Norman's Avatar
I like to use a gasket and some non hardening "black" gasket sealer. Make sure and don't over torque the bolts.
Old Jun 8, 2006 | 01:19 PM
GreyTD's Avatar
Also check to make sure the cover has not been bent ie pulled at bottom to let oil out without removing top bolts. The gasket I thought was reusable, has 2 rubber seals inbedded in the seal, unless early trucks didn't come with it. Bolt torque I think is 30 to 35lbs max. anything over that will warp the cover causing weepage.
Old Jun 8, 2006 | 05:58 PM
jimmy_jgr's Avatar
Thanks for the help, I checked the color of the sealant and its grey, with mopar fluid in it from the dealer hypoid 80w-90 I think, is that sealant compatible with the fluid? I dont see any warp while its on, but I will check it this weekend when its not in use, Also I go to the farm alot, is there a chance that hitting something with the pumpkin could damage the cover? also all bolts are tight and to spec.
Old Jun 8, 2006 | 06:06 PM
nitrousn's Avatar
Mine had the gray befor i resealed the cover with the red/orange and went to synthetic. If your out of warranty or have a deductable it would be cheeper to do it your self.
Old Jun 8, 2006 | 11:35 PM
dodgezilla04's Avatar
toss the stamped cover and put on a maghytec or pml cover. no more leaks.
afate45
Jun 7, 2014 12:08 AM
Grim Reaper
15
Sep 9, 2005 08:39 PM
StevenB05
Aug 22, 2005 02:43 PM
shaft
13
Jan 29, 2004 07:37 AM
Commatoze
Apr 2, 2003 12:53 PM
