Front Axles...?
Old Oct 11, 2005 | 09:16 AM
Greguw's Avatar
Smile Front Axles...?
Hi guys
Still researching what year dodge I am going to go with , I am leaning toward a 97 dually or a 2002 duelly .... It's really hard for me to leave anything alone ... I love to tinker , so for me to buy a new truck is not out of the possablitys , but I figure if I get a little older truck like a 2002 , leaves a little more spending money for improvements .
My question is about the front axles , from the reading I have been doing on your site 2002 was the last year for dana ...I really like dana ...lots of parts out there .
My question are the dodge front axle's always spinning the front axles ...I did see some where , I think dynatrac the conversion , I would figure you would get a little better fuel mileage not turning those hubs .
Thanks guys
Greg
Old Oct 11, 2005 | 09:53 AM
jd4030's Avatar
Yes, 2002 was the last year they used the Dana axles. I know at least for my truck (built march of 02) both the front axles turn & the front driveshaft, so that for sure hurts mileage. Some other folks have posted that it was for a limited production time that the front drive shaft turned. My brothers 99' does not, but the axles do.
Old Oct 11, 2005 | 10:15 AM
CTD NUT's Avatar
All 2nd gens with the exception of the 02.5's had a vacuum operated center axle disconnect system that splits the passenger side inner shaft into 2 pieces and stops the ring and pinion and front shaft from spinning in 2WD.....only the spiders and side gears spin. The 02.5's eliminated the CAD so the entire front driveline will spin in 2WD.
Old Oct 11, 2005 | 11:25 AM
jd4030's Avatar
What system did the 02.5 go to to join the axle's? I thought it was the CAD as well?
Old Oct 11, 2005 | 11:58 AM
CTD NUT's Avatar
No "system" used on the 02.5's.....the CAD was simply eliminated.
Sep 22, 2019 07:27 PM
95black2615
Dec 22, 2007 10:54 PM
bigbrowndog
Sep 2, 2007 08:16 PM
SkyHarborCowboy
15
Sep 9, 2005 11:50 PM
