Front Axle Diff
Front Axle Diff
Hey everyone,
Just got thinking, since the differentials on the front axle of our 4X4's are Open. Is there an easy way to make it a LSD or a Locked Diff? I got thinking when in 2wd, the diff/4x4 drive shaft and all of that is free spinning anyways, so having the front diff welded wouldn't hurt anything. Then once you put it in 4wd, the front axle has both wheels spinning equal.
I guess my question is, can they be welded? Or would a Detroit Locker be better since they can engage/disengage?
Thanks!
Thanks!
I was just curious to what the easiest thing, if it is possible to do. I just got thinking about it while I was making a path threw some snow in my yard.
Let's just say if someone were to weld the front diff, that shouldn't affect anything in 2wd should it? Like the front left tire, differential and middle axle are spinning, but not locked to anything, correct? Then once put into 4wd (which should be used on slippery surfaces anyways) the front axle would be locked with the rear and all 4 tires would spin?
I would imagine it would make it want to pull to the left, since the left tire is now driving the axle shafts, diff, driveshaft and t-case. I'd go with an ARB before running a full locker or spool.
Brad
I think you are correct. I personally wouldn't do it, but I do have a beater Jeep Cherokee that's set up exactly as you describe with welded front diff. As long as the axle is vacuum actuated the two front wheels will spin independently in 2wd. But, I agree with the others that once you put it in 4wd it will be very hard to steer, even in dirt. It is very hard on the axle shafts for sure.
Brad
Brad
I run in the snow from November/December to March which isn't too long, but it sure would be nice to have a LSD style front axle instead of open
I wouldn't try that without converting to manual hubs first. Personally, if I had the spare cash, I'd go for the free-spin kit then a Detroit Locker. Without the manual hubs, ARB looks like the only good option.
Randy.
Randy.
afate45
Jun 7, 2014 12:08 AM
rustydeeretech
17
May 21, 2011 03:05 PM
Doj Dewd
Oct 9, 2008 08:24 PM
UnrulyNFS
Competition / Pulls / OffRoad
Jun 24, 2006 03:26 PM
