Foil on the Alternator Wire?
Well, as I am jobless right now, I don't have the money for a new alternator, which may well fix it. Even so, since the alternator acts right, as far as charging, I hesitate to replace it anyway. I think I am going to give the APPS grounding method a try first. That one makes the most sense to me, and has more specific instructions to accomplish.
Thanks,
Chris
Thanks,
Chris
I'll post the info for the replacement brushes when I find it, it might be worth trying.
I had the same problem, being so frustrated, I broke down and bought a reman Alternator from Autozone and it was fixed. The truck now runs great. Additionally, I tried all the above mentioned and none worked.
Good Luck.
Reman 120v Alternator from Autozone. = $139.00 (not too bad for this truck I guess.
Good Luck.
I tried everything ...CLeaned all 6 grounds..Reset APPS, cleaned battery terminals, added noise supressor etc....It was a weak battery on the passenger side..Bought 2 new batteries and havent seen the problem since....( year ago)
I fixed mine by running a dedicated ground from the passenger bat neg terminal to the computer on the firewall and coated both ends with conductive copper antisieze. Soved the problem for basically free since I had everything sitting around. I was going to replace the Alt if that fix didn't work. Glad it did, saved me about $200.
However it does sound like a bad alternator in your case...
Brad
spoolinNpullin
Oct 21, 2018 09:02 PM
5.9Excursion
Mar 13, 2008 07:08 AM
TPilaske
16
Nov 22, 2002 08:15 PM
