Flushing Coolant
Old Mar 10, 2007 | 03:35 PM
Ridiculous's Avatar
Flushing Coolant
what's the best way to go about doing this?
Old Mar 10, 2007 | 05:58 PM
fbx22's Avatar
you might try these pages
http://dodgeram.org/support_pgs/diesel_ix.htm
lots of great info on this site
Old Mar 10, 2007 | 10:09 PM
Ridiculous's Avatar
hey good to see you again buddy! i appreciat all your info! i'll check out that link and if i don't get my questions answered i'll keep asking.
i told ya i was gettin all the info i need
Old Mar 10, 2007 | 10:24 PM
DL1221's Avatar
On my 01 I actually took the time to take the radiator out to flush the system. It wasn't that hard, I left the fan and clutch in place, just took the upper radiator hose out then unbolted the shroud and moved it out of the way while I pulled out the radiator. Then I removed the thermostat housing and disconnected one heater hose. To flush the system, I used a garden hose to flush out every opening: lower radiator hose, thermostat opening, heater hose, until clean water came out. Then I flushed it with some clean coolant to get all the tap water out. While the radiator was out I power cleaned the outside of it to get all the oily gunk from the puke bottle. Then a new 180 thermostat and new coolant. Runs cool as a cucumber now.
Old Mar 10, 2007 | 10:30 PM
Ridiculous's Avatar
ok, so what if i just wanna do it without removing the radiator. is there a petcock i can open or something. i figured i'd just drain the coolant, fill with water, drain again, fill with coolant.
if there's a problem with this procedure, let me know and talk me out of it.
Old Mar 10, 2007 | 10:38 PM
fbx22's Avatar
wow, well I certainly would not tear the whole radiator out of the truck for this but thats my preference, whatever works.
Here is a step by step guide to coolant changes
http://dodgeram.org/tech/dsl/cooling-sys/antifreeze.htm
Old Mar 10, 2007 | 10:40 PM
Ridiculous's Avatar
that's what i thought, not unless you're taking it to a shop and having the radiator flushed too.
and hey, where'd you find that i could not find it
roger2
27
Jun 9, 2010 11:09 AM
JSPulliam21
13
May 29, 2009 03:04 PM
ckennedy
33
May 21, 2007 01:45 PM
apache
May 18, 2005 07:58 PM
Rayzor
Aug 19, 2003 07:52 AM
