First Oil Change
Old Mar 8, 2008 | 11:25 AM
DodgeCowboy's Avatar
DTR's Cow Boss
First Oil Change
Hi fellers this is the first time I have had too change my own oil in this thing and its a different animal than all the gassers I have always done. So I know our truck take like what 10qts of oil in the crank case and a quart in the filter. So I bought 3 gallons of delo and filled according and it looks as though I might have over filled it but I don't know and don't want too drop oil if I don't gotta.
Old Mar 8, 2008 | 12:53 PM
Deezel Nate's Avatar
I always just pour 3 gallons in the valve cover and call it a day. I don't bother filling the oil filter, never have on any vehicle.
Old Mar 8, 2008 | 02:40 PM
mini14's Avatar
just put the 3 gal. in u wont have any probs.
Old Mar 8, 2008 | 03:16 PM
SIXSLUG's Avatar
It'll hold 3 gallons w/o any overfill concerns.
Kurt
Old Mar 8, 2008 | 03:21 PM
DTR's Cow Boss
Sweet thats what I thought just checking thanks all. Going too start doing my own now tired of paying too have it done and my shop is finally cleaned out.
Old Sep 10, 2008 | 09:04 AM
floodlight's Avatar
I've got a 98.5 RAM 2500 with 134 thousand miles on it and I live in Canada. I'm about to make my first oil change. I check the manual and it recommended to use 10W30 for temp. 70F* or lower. Is that right? Or should I stick to 15W40? Temperature here is hovering around 70F* during day time but last night it dropped to 40F* and it's going to get colder as get in the Fall and Winter obviously....What do you think, should I put in 10W30?
Old Sep 10, 2008 | 09:13 AM
Hillcountry's Avatar
I think 5W40 is what many use in the winter as it eases startup and doesn't get so think. It is also easy to find as diesel rated.
Old Sep 10, 2008 | 10:24 AM
pind's Avatar
Flood
If it helps, I run 15w40 in summertime, and down to about 0 or -10C. usually I am due for an oil change by then anyway, and I go to 0w40 for the winter months, changing back at the first oil change after the freeze is over for the season.
Old Sep 10, 2008 | 02:07 PM
dozer12216's Avatar
10-30 might be more of light duty oil, but will do fine. I favor the 5-40 or the 0-40 syn if it gets brutally cold. The syn will flow easier than straight dino oil.
Old Sep 10, 2008 | 02:36 PM
xtoyz17's Avatar
Wait wait wait. You guys throw in the extra quart? I've never read of anyone doing that before which is why I'm surprised! My truck takes 11.5 qts and I'm always wishing I could dish the last little bit. Looks like its going in from now on!
Old Sep 10, 2008 | 02:47 PM
blake2500's Avatar
What do y'all in the southern states run in the winter? I'm in North Georgia and it gets somewhat cold here in the winter. I do most of my driving to and from work about 1hr each way before dawn and after sunset in winter.
Old Sep 10, 2008 | 03:09 PM
xtoyz17's Avatar
I still run 15W40 in the winter and I see weather as cold as -20, to -30 Fahrenheit. Thinner oil is easier on the engine when starting, but once it's up and running and warmed up (especially over the period of an hour), it's a moot issue.
Old Sep 10, 2008 | 08:02 PM
floodlight's Avatar
I just finished the oil changed and put in 10W30 synth. . I noticed that on the 10w30 bottle it says Gazoline Rated. Does it mean it's no good for Diesel engine?
Old Sep 10, 2008 | 08:12 PM
It has to be rated for diesel engines...gasoline rated oil does not capture the soot like diesel rated oil. I would change it out soon.
Old Sep 10, 2008 | 08:17 PM
klx650a2's Avatar
I run 0w40 synthetic year round...
