Fault codes
Old Feb 13, 2006 | 10:31 AM
Maverick2001's Avatar
Fault codes
My truck started showing two fault codes and I was wondering if you guys could help me. The first code is P1693 and all I can find is that it's a companion code for something.
The second is P0500 and according to the tech facts:
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
does anyone know what this affects because it has had power problems for about a year now.
To be honest I'm pretty fed up with the truck. I've had nothing but problems with it and as soon as I get one thing fixed something else falls apart. I've had it to several mechanics including three different dodge dealerships and no one can find the problem. It has zero power and gets between 12 and 13 mpg on the highway fuel pressure Idling is between 13-14 psi crusing 10-11 psi and pulling or under heavy acceleration is 6-8 psi. The dealership swears its not the injector or lift pumps. I just changed the fuel filter last week so that is not the problem. sorry about the long post I really need to get this figured out.
thanks,
Dave
Old Feb 13, 2006 | 11:16 AM
piperca's Avatar
Just a suggestion regarding the power; you may want to try cleaning/replacing the MAP and IAT sensors. They are located on the driver's side of the block, to the rear. The MAP is the first sensor past the fuel filter canister and the IAT is all the way back, almost on the corner of the block. Hope this helps!
Old Feb 13, 2006 | 11:20 AM
StrokeThis2500's Avatar
SYMPTOM
P0500-NO VEHICLE SPEED SENSOR SIGNAL
TEST NOTE
This symptom is diagnosed using the test P0500 NO VEHICLE SPEED SENSOR SIGNAL.
WHEN MONITORED
The Vehicle Speed Signal test is run when the Engine boost is greater than 7 psi and the Engine rpm is above 1024 rpm but less than 2784 rpm .
SET CONDITION
The code is set if no Vehicle speed is recieved from the CAB Module for more than 15 seconds for 2 consective trips.
POSSIBLE CAUSES
CAB module diagnostic trouble codes present
Vehicle speed signal circuit open
Vehicle speed signal circuit shorted to voltage
Controller Antilock Brakes (CAB)
Powertrain control module (No vehicle speed sensor signal)
Vehicle speed signal wiring harness observable defect
Vehicle speed signal circuit short to ground
Old Feb 13, 2006 | 11:53 AM
Thanks Piperca,
I'll check the sensors as soon as I get out of class today. So with the speed sensor I need to take it in and have someone diagnose it?
Thanks,
Dave
Old Feb 13, 2006 | 07:33 PM
Dr. Evil's Avatar
Ive gotten the P0500 from spinning the rear tire. In most cases it will go away after a certain number of starts or if you pull the battery cables with the ignition on.
Old Feb 16, 2006 | 11:39 AM
Talking Found Cure for the Truck
Actually I solved all my problems with this truck on monday with a quick trip to my friendly neighborhood dodge dealership. I traded the truck on an 05 short box. I want to say thanks for all the information and suggestions. The truck was a lemon from the get go and I think I'll be much happier.
Dave
xp8103
May 18, 2005 01:54 PM
ARAcummins
Sep 27, 2003 04:32 PM
cmckinney
Aug 6, 2003 03:28 PM
KC Super 80
Jun 10, 2003 12:12 AM
hvanflee
Mar 10, 2003 10:53 PM
