Every thing broke at the same time!
Old Sep 16, 2006 | 08:23 AM
Roadstar's Avatar
I was driving the other day and had dead petal and check engine light.I scanned the codes and it said I had a bad throttle positioning sensor, failed lift pump,and a bad injection pump.Is it possible for everything to go at once like that.Any info would be helpful. Thanks.
Old Sep 16, 2006 | 08:27 AM
Geico266's Avatar
Well, it didn't go bad all at once, you just pulled the codes and found the list of stuff to fix. You need to do more preventive maintenance.
Get a fuel pressure guage, after you install a new LP & IP.
Old Sep 16, 2006 | 08:33 AM
Roadstar's Avatar
I replaced the lift pump and tps both within the last year and a half when the truck was still under warantee. This the first time i have seen the check engine light since ive owned the truck.I also plan on adding a second fuel pump to try to avoid any problems down the road.
Old Sep 17, 2006 | 09:11 AM
Mopar1973man's Avatar
First thing fill in you signature so we know what you got...
Second off... Do you have any gauges in your truck? If not I would HIGHLY SUGGEST you get a set quickly!
Now as for the error codes I'm sure you didn't get them all at once. The LP pump was failing for a long time before it throws a code, then the IP (VP44 pump) must been without fuel pressure for sometime to throw a code. (Fuel pressure gauge could of saved you here!)
As for the APPS sensor just do a APPS reset and all is well...
A lot of money could of been saved if you bought a set of gauges!
Old Sep 17, 2006 | 02:03 PM
mgstroker95's Avatar
gauges got have those gauges!
Old Sep 18, 2006 | 08:56 AM
You need to find Fuel Pressure, Pyrometer, and Boost Pressure. In that order... If you have a automatic transmission add a Transmission Temperature.
This will help you pretect you investment from getting damaged. Being anything that you got to repair usually costs more than a gasoline engine by far!
But like you found out if you knew your lift pump was dieing (Fuel pressure gauge) you could of saved a lot of money on the replacement of you VP44 injection pump!
Like you I learned to late too... I lost a LP and VP44 but I was still under warranty. 50K miles... That was the whole reason why I got the gauges...
J Lent
60
Nov 3, 2009 09:14 PM
newconcorddodge
Oct 6, 2008 09:05 PM
Hondo
Mar 5, 2005 01:22 PM
Dufrain
Jun 7, 2004 11:25 AM
dma251
May 13, 2003 02:24 PM
