engine roar?
Old Jun 14, 2005 | 05:45 PM
DieselNomad's Avatar
engine roar?
when accelerating it sounds like a jumbo jet is taking off under my hood , loud fan sound or simalar? just started doing this here recently, and no clue as to why?
Old Jun 14, 2005 | 05:55 PM
dezlsmkr's Avatar
Sounds like a bad fan clutch
Old Jun 14, 2005 | 06:04 PM
whats the ball park price on a fix for that?
Old Jun 14, 2005 | 06:13 PM
dezlsmkr's Avatar
I dont think there too bad you should be able to get them just about anywhere. If for certain that is what it is.
Old Jun 14, 2005 | 06:28 PM
good to know, having the rig in tommorow for a little work, have them run through her. thanxs
Old Jun 14, 2005 | 08:34 PM
J BODY's Avatar
Come down here and you'll hear it all the time......it was 113 here today.
Old Jun 14, 2005 | 08:42 PM
farmer dave's Avatar
How do you know if it is a bad clutch fan. Mine is loud for a while when taking off and then quiets down, but running the AC the other day and it was lasting much longer before it got quiet. Could this be a bad clutch fan? Is there an easy way to check it?
Old Jun 14, 2005 | 09:02 PM
i get the the same sound when i have the O/D turned off at high rev's @2500rpm.
Old Jun 14, 2005 | 10:42 PM
rbox's Avatar
thats just your fan clutch kicking in because of the hotter temps. Perfectly normal unless it doesn't go away in cooler weather. Mine does it in the summer all the time. it does it more when your AC kicks in because the AC creates heat under the hood.
Old Jun 14, 2005 | 10:43 PM
Timmay2's Avatar
Re: engine roar?
They call that a turbocharger.
Old Jun 14, 2005 | 11:03 PM
thats a hell of a turbocharger, must be just the hot weather.
Old Jun 15, 2005 | 08:54 AM
Mopar1973man's Avatar
If it roars all the time hot or cold then the clutch is bad.
But if it gets quiet again then it's cycling normally.
Old Jun 15, 2005 | 07:31 PM
it must be the hot weather not use to these kind of temps up here, it does stop after a while.
Old Jun 15, 2005 | 10:24 PM
Mine does it in hot and cold weather, but it stops after a short while. It stays on longer when the AC is on but will finally turn off, but when you stop it does it again. I guess it could have been from the heat, it was in the high 80s-90s last week when I was using the AC. So it sounds like some roar is normal, right?
Old Jun 15, 2005 | 10:27 PM
phox_mulder's Avatar
I'd say it's pretty much normal.
After the "lights dimming after a cold start", it's gotta be one of the more popular "newbie" questions.
phox
