Engine Oil Pressures
Old Apr 3, 2003 | 10:20 AM
Hottrodjim's Avatar
I am wondering what the various oil pressures are on the CTD's. When I start my engine, the oil pressure takes three to four seconds to build and then it quickly jumps up to about 40 PSI. When running above idle the pressure is up around 65 PSI and then drops back to about 40 at idle. The thing that scares me is the three to four second lag to build pressure upon fireup. A lag in pressure buildup from my experience usually indicates worn bearings etc. I may try to find a spot to connect a mechanical gauge that I have to see if the lag in pressure is showing accurately on the dash guage. Any suggestions?
Old Apr 3, 2003 | 10:28 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Engine Oil Pressures
It takes a few seconds to get the Computer up to speed processing the data from the senders.<br>The oil pressure is there, the guage just suffers from &quot;Jet Lag&quot;.
Old Apr 3, 2003 | 10:42 AM
Hottrodjim's Avatar
Thanks Shovelhead,<br>I am new to Diesels and very paranoid because of it.
O.T
Sep 18, 2007 12:50 PM
toupee
Jun 27, 2007 04:19 PM
Push Rod
Dec 26, 2002 03:31 PM
Jones0027
15
Nov 3, 2002 10:34 PM
BigBlue
Oct 16, 2002 04:58 PM
