Engine Oil Leak from VP44 Mounting.
Old Jul 19, 2011 | 09:52 PM
george7941's Avatar
I have been slowly eliminating the various little oil leaks from the engine.
I have a significant oil leak(enough for a couple of drops of oil on the ground every time I park) which seem to come from where the VP44 is mounted to the back of the aluminium timing case. There is a round boss on the rear of the timing case on which the VP44 mounts. Strangely enough the oil doesn't come from the bottom of this mount but from around the 3 O'clock position when looking at the back of the case. Of course I can't see the leak because it is hidden by the VP44 but feeling around with my fingers indicates the location of the leak.
Does this mean the o-ring on the VP44 where it goes into the timing case is bad and I have to pull the VP44 to replace this o-ring?
My tappet cover gasket is fine and not leaking at all.
Old Jul 19, 2011 | 10:11 PM
torquefan's Avatar
The other possibility is that the gasket is leaking between the gear housing and the front of the block. To determine a leak like that, I try to hose the area clean with brake clean and compressed air, then idle the engine until I can just begin to see oil appear again. One of those small video inspection cameras can be real handy, if you can borrow one from somebody.
Old Jul 20, 2011 | 04:10 PM
george7941's Avatar
Thanks. I have a Ridgid inspection camera but I broke the head off. I will use an inspection mirror to see if I can pinpoint the leak.
trailduster440
Jan 15, 2013 02:24 AM
Chummins93
Jul 23, 2012 08:46 AM
george7941
Nov 28, 2009 09:28 PM
Timmay2
25
Feb 12, 2006 01:00 AM
donhov
26
Jan 6, 2006 07:29 PM
