Engine light
Engine light
Ok, so had it on cruise control today, and an engine light came on. After I got stopped and shut it down, I pulled codes. Came up with a P0237. I did a search for it here, but got a little confused. Also got a P1693. Maybe someone can give me some insight.
Thanks
Thanks
P0237 - MAP Sensor Voltage Too Low
P1693 - DTC Detected In Companion Module -OR- DTC Detected In PCM/ECM
So basically you need to check you MAP sensor connections and/or replace the MAP sensor. The second code is to alert you to a another problem on the other module but it might of cleared it self up. You will need to get a code reader to see it...
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
choppers555
Oct 16, 2007 12:29 PM
Stevenc
Dec 28, 2004 08:29 PM
