Engine Knock
Old May 3, 2008 | 01:21 PM
B&B Transport's Avatar
Engine Knock
I have a loud engine knock at all rpm ranges, seems to run fine, oil pressure is good. I took it to a dodge dealership and was told that after the injector cut out test was done the noise went away on cylinder #6. They are telling me that it is a problem with the bottom end a spun rod bearing or main bearing for cylinder #6. I still think it could be an injector but am unsure. Has anyone else seen this or had this happen to them?
Old May 3, 2008 | 07:47 PM
nitrousn's Avatar
Sounds like you are bombing it and pull a trailer. My bets are number 6 has a scored piston from to high egt,s.
Old May 3, 2008 | 08:21 PM
Fern's Avatar
Plus I heard the Edge EGT values are off up to 200 degrees or more maybe. At least thats what I read in another thread when an Edge owner spoke with an Edge tech. Good Luck.
Old May 3, 2008 | 10:05 PM
WestTN's Avatar
Another possibility would be number 6 piston scored due to use of a FRAM oil filter.
Old May 3, 2008 | 10:35 PM
johnh's Avatar
Old May 4, 2008 | 12:37 AM
pind's Avatar
west has it right. the seal ring on fram filters has a tendency to break down, sending small bits of itself into the oiling system.
These bits tend to lodge in the piston cooling nozzles, and screech, you have a bad cylinder.
Sucks, but that is why there is a recommended filtration list for all major OEM's
Old May 4, 2008 | 04:27 PM
I have only used the dodge filters for the oil and the oil changes done by a dodge dealer. I have the edge set at 1200 degrees on the egt, so I dont think this is to high is it? I have already ordered a new complete running engine I just did not want to hear that it was possible that the injector was causing the noise. I to thought that something was wrong in the bottom end. I have only had the truck for 2 months and the previous owner maybe didnt change oil enough. Any other info is appreciated.
Old May 4, 2008 | 05:46 PM
Fern's Avatar
My point was that it says EGT's are at 1200 degrees, but may really be between 1400-1500 degrees. I do not speak from first hand knowledge just from what I have researched because I was thinking of getting the Edge with Attitude myself, but now am leaning towards Adrenaline because I have not heard of similair problems with it. You may want to invest in mechanical gauges just as a precaution and to protect your livelyhood. JMO.
Old May 4, 2008 | 06:34 PM
Mopar1973man's Avatar
Be aware some of Dodge's filters are also made by FRAM...
Shocking huh???
Old May 4, 2008 | 07:26 PM
WestTN's Avatar
Where was your thermocouple, before or after turbo? If it was after, you may have burned it up.
Old Apr 22, 2009 | 10:41 PM
jpstanley3's Avatar
well arent we having all the luck? mine is in the shop with a spun #6 rod bearing. but it has 138k on it and i've only had it 10k and 6 months. its a 2006 dually with a 6 speed and i'm starting to think that somebody had a chip in it before i got it. the top of EVERY piston is melted and some rings are broken. there is severe cylinder wall scoring especially on #6...but its getting a used motor out of another 2006 with "60k" so hopefully i dont get screwed again.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
