DTT Transmission problem / where to get work done
Old Dec 29, 2008 | 07:36 AM
btown647's Avatar
You can see my mods in my signature below. but here is my problem. and this just happened i didn't pull anything heavy or put stress on it or anything. for one it is SUPER sluggish starting off it goes almost all the way to 1700 rpm before it even starts moving. then the infamous kick that it used to give me from the shift to second is gone it almost seems like it never shifts. at 65 mph it stays at 2600 rpm the whole time and switching on or off overdrive seems to make no difference. is it as simple as a fuse? or what else could it be? and my next question is id like to take it someplace but i don't know where i should take it and who can work on a dtt. i am in buford ga 30518 if anyone knows of someone close.
Old Dec 29, 2008 | 12:03 PM
j-fox's Avatar
Call DTT. It sounds like the trans is in limp home mode. 2nd gear starts and won't up shift.
Don't drive it until it is figured out.
You don't have your profile filled out, so we can't help with WHERE do I get it fixed.
Where are you?
Old Dec 29, 2008 | 01:02 PM
btown647's Avatar
Old Dec 29, 2008 | 02:14 PM
paulb's Avatar
It is probably either the govenor pressure solenoid, or the governor pressure transducer. Both are know problems, and are not in anyway a fault of DTT. Give DTT a call, and they can tell you exactly what to do. It is really pretty simple to fix.
Paul
Old Dec 29, 2008 | 06:59 PM
btown647's Avatar
i called dtt and they are by far the most helpful people i have ever met in my whole life!!! (exept for all of you guys of course) but yeah i talked to them and they said its in limp mode and a bunch of ways to test it to find out what exactly it is. great people :-)
Old Dec 29, 2008 | 10:10 PM
Shagginwagon's Avatar
Yes, they are awesome people.
pwrtripls1
Jun 6, 2010 10:26 AM
Firstgenfanatic
Feb 16, 2010 08:57 PM
dieselfuelonly
NCDTR #18
Oct 1, 2008 09:09 AM
Ramdriver15
Jan 24, 2007 09:33 AM
