Drums to discs...a little different though..
Old Apr 24, 2009 | 06:02 AM
89dieselkong's Avatar
I am going to be doing a DRW to SRW swap. I have a SRW Dana 80 from a '96 with drums that is going to be put on a 2002 w/discs. Is the swap as easy as removing backing plates and drums from the '96 and then bolting on the parts from the 2002 axle? The 2002 is a DRW Dana 80. If not what might is required to do the swap?
Also, if that doesn't work, can the axle from the '96 be bolted under the 2002 with the drums intact and have them work?
Thanks
Old Apr 24, 2009 | 06:48 PM
Anyone????
Old Apr 24, 2009 | 10:41 PM
johnh's Avatar
why don't you use the '02 80???
Old Apr 25, 2009 | 06:57 AM
The '96 has 3.54 gears instead of my 4.10's. Most of my driving is highway.
Old Apr 25, 2009 | 11:27 AM
johnh's Avatar
if it was mine, i would look into just changing the gears, .... i think they are interchangeable.
i don't think the brakes will swap, somebody correct me if I'm wrong...
Old Apr 25, 2009 | 03:43 PM
dozer12216's Avatar
Brakes no swappee! You could use the rear drums, but everything is wrong. ABS would not be calibrated correctly. The list goes on. Change gears and upgrade to better locking diff at same time. JMHO
coiler33
Nov 26, 2007 12:32 PM
Deezel Nate
19
Jun 7, 2007 10:45 PM
scottmn1
Nov 30, 2006 08:41 PM
Korney
14
Jul 8, 2005 03:43 AM
Lrdchaos
Apr 3, 2004 02:34 PM
