Drivetrain howl?
Old Apr 6, 2011 | 03:04 PM
mamm7215's Avatar
Drivetrain howl?
I guess that's how I'd describe it. Happens at speed around 60mph, little less at slower speeds. One thing is odd, when I go into a right hand turn (ie, the highway or road banks right, not a right turn from stop) the noise goes away. Doesn't go away on a left leaning turn or straight. I had low tire pressure in the passenger front side but topped them both up to the same and it's still there. I did some searching and am concerned it's a transfer case bearing or something. Budget's a bit of an issue right now, is this something I can fix myself? I'm pretty decent at mechanics. Could it be something else?
Thanks.
Old Apr 6, 2011 | 03:58 PM
KATOOM's Avatar
Sounds like a front wheel bearing. Jack up the front tires and see if you feel any movement.
Old Apr 6, 2011 | 04:39 PM
Hodge's Avatar
x2. When you jack up the front end, rotate both wheels. You should be able to hear the bad bearings. Make sure you check both- if one goes, the other might not be far behind it.
Old Apr 6, 2011 | 07:27 PM
mamm7215's Avatar
Yep, driver's side front, about a 1/16th of play at least. None on passenger side, tho' I replaced that one about 2-3 years ago.
sspearl
13
Aug 13, 2009 01:27 PM
Brutus2003
Aug 3, 2004 09:30 PM
odie2219
Mar 22, 2004 05:24 PM
Mechanos
Jan 28, 2004 08:41 PM
