dreaded 53 block
Old Feb 6, 2004 | 12:35 AM
Barry Smith's Avatar
This is the first I've heard of block cracking?
Old Feb 6, 2004 | 12:48 AM
Dr. Evil's Avatar
Originally posted by DODGE4X4
Ok I have ruled out that I have a 50 series engine( I looked all over the place and read all 8 pages of the TDR web page post to help me find it.) Ok so the good new is that I don't have a 53 but which engine do I have? My truck was made in October 2000.
What do ya mean "what engine do I have"?? Obviously, its a 24V...do you have a 5 speed, 6 speed or auto???
Old Feb 6, 2004 | 12:50 AM
DODGE4X4's Avatar
Look at this site. http://www.turbodieselregister.com/f...=cracked+block
Dr. Evil's Avatar
Barry, this is relatively common......the #53 blocks, used from 97-2002 were made in Brazil....the casting along the water jacket (I believe) is 6 mm instead of the usual 12mm.....so, if you have a #53 block and work your truck hard or have it radically bombed, it could be an issue for you.
Old Feb 6, 2004 | 12:51 AM
DODGE4X4's Avatar
Well Doc. I mean do I have the Mexico or the Brazil block.
Old Feb 6, 2004 | 01:10 AM
Dr. Evil's Avatar
dunno.....
Old Feb 6, 2004 | 04:57 AM
Thank you guys! I'll check into this!
Old Feb 6, 2004 | 08:46 AM
Mechanos's Avatar
My truck was built in August 2000 and was built in Mexico. I have a large (about 1.25" high) numbers cast into the block right by the power steering pump. The numbers are "55", so I'm assuming I have the Mexico block and not the dreaded "53" Brazil block.
Old Feb 6, 2004 | 09:04 AM
Tartarus's Avatar
According to Cummins:
No 53 blocks were installed in '02 trucks. Very few were installed in '01 trucks.
Strangely enough, the Brazillian/Mexican-manufactured 56 block that was installed in many '01 and nearly all '02 trucks is the strongest ISB block made to that time. 14mm jacket castings. Superceded the 53 -- was Cummins's "fix".
Old Feb 6, 2004 | 10:40 AM
Dr. Evil's Avatar
14 mm as opposed to 6 mm in the #53 (so Ive heard).....that just doesnt seem right.
Old Feb 6, 2004 | 11:48 AM
HOHN's Avatar
I have the Mexican block in my '02-- the strongest second gen block made.
The Mexican blocks are identified by the LACK of tall 5x numbers. The 53, 54, 55, etc is a Brazilian block. The blocks that just have a bunch of small character, and no large numbers "5x" are the Mexican blocks.
Rumor has it the Mexican blocks are case with a slighltly higher Nickel content, making them stronger than even the latest Brazilian blocks which were dimensionally identical.
At least, that's what I have been told.
My truck was built in July '02 so it's one of the last off the line.....
Justin
Old Feb 6, 2004 | 02:56 PM
Wilson's Avatar
Mine is a 55 block, so what does that mean?
Old Feb 6, 2004 | 03:26 PM
HOHN's Avatar
It means the block is one you'll never have to worry about.
Old Feb 6, 2004 | 03:44 PM
Wilson's Avatar
Thanks for the info.
Old Feb 6, 2004 | 08:36 PM
DODGE4X4's Avatar
YES I HAVE A TACO BLOCK
megajoltman
Mar 21, 2007 01:37 PM
ccraver
Jun 5, 2006 05:43 PM
GCSS
13
Aug 7, 2005 12:31 AM
Rauschbo
14
Feb 19, 2004 10:47 AM
tool
Dec 27, 2003 02:27 PM
