Draining a NV5600
Old May 16, 2005 | 03:14 PM
bpk's Avatar
bpk
Draining a NV5600
Can someone please tell me which bolts to take out off the PTO cover to drain the old fluid? Thanks in advance.
Old May 16, 2005 | 03:29 PM
67HotRod's Avatar
Do you mean the drain plug on the other side of the trans?
Old May 16, 2005 | 03:38 PM
bpk's Avatar
bpk
Yes I thought you used the bolt holes from the PTO covers on either side of the trans to drain the thing. Maybe I wrong
Old May 16, 2005 | 05:35 PM
Homestead's Avatar
Use the lowest hole on the PTO cover. The NV5600 doesn't have a conventional drain plug like you would normally look for.
If you want to go the extra step, pull the PTO cover completely and clean off the magnet inside. You will be suprised what is on it.
Hope it helps.
Old May 17, 2005 | 12:07 AM
bpk's Avatar
bpk
Thanks Homestead, I'll pull the cover.
Old May 17, 2005 | 09:42 AM
67HotRod's Avatar
Hum, the drain plug on the other side must have been made espically for me. Looks factory though.
Old May 17, 2005 | 05:27 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
I thought some had boss' for drain plugs but they werent drilled and tapped.................... been a long time since i looked though.
Pull the lowest bolt in the PTO cover either side
Old May 17, 2005 | 07:24 PM
Gear Poet's Avatar
No drainplug on any NV5600 I've ever seen.
If you want to do a -really- good job, take both PTO covers off, both sides. Pull the magnet out from the driver's side PTO hatch, and clean it off. (Can't get in there from the other side because of the gears and rails.) Then take a rag or paper towel and "push" out the remaining fluid in the bottom - there will be about a quart, a dirty quart, that won't drain.
Old May 17, 2005 | 07:40 PM
caper's Avatar
Yes ,that last quart is a to get out.
Old May 17, 2005 | 07:52 PM
bpk's Avatar
bpk
OK, Thanks to all
miketriton
15
Jan 16, 2009 05:24 PM
KTURN
Aug 13, 2004 11:18 AM
bowhunter96
Jul 14, 2004 11:12 PM
Douglas
Feb 2, 2004 05:47 PM
nwilliams98
Oct 8, 2002 09:53 AM
