does tranny fluid really matter?
Old Aug 19, 2009 | 11:50 PM
mttjma2002's Avatar
So on my new tranny im having some problems, i called a shop and they said make sure it has ATF 4 and if not change it ASAP. the guy that built my tranny said it didnt matter and i believe he just put in like regular fluid not the ATF stuff. Should i change it or does it matter?
Old Aug 20, 2009 | 12:53 AM
Fishin2Deep4U's Avatar
The higher the number, the more friction modifiers that are added tot eh product. This is a polite way of saying slip. Basically, people want smooth shifts in newer trucks and the +4 helps that.
If you have a rebuild you are fine either way. However, many stock transmissions need the added friction modifiers for the OEM seals.
If you get any shudder, just throw a bottle of Lubegaurd in with the cheap fluid.
Dave
Old Aug 20, 2009 | 04:19 AM
carl48's Avatar
the auto was junk when it left the factory. i will bet you did not upgrade when rebuilt. so still junk i suggest you change it now to synthetic atf4
Old Aug 20, 2009 | 04:44 AM
67HotRod's Avatar
What type of problems are you having? Is it slipping or shudder? I have goerend vb/tq and Dave told me to use ATF3 with the lubeguard, not the ATF4. Need more info to help ya.
Old Aug 20, 2009 | 12:56 PM
dozer12216's Avatar
Chrysler spendt mega dollars engineering atf+4 with a superior high temp tolerant additive package. No earleir ATF or snake oil is an improvement.
Friction moddifiers enhance the griping ability of ATF not allowing to slip(as much) in gear. Much like Ford type F was superior to early Dexron in clutch enhanching abilities. However Type F was not as temp tolerant or have good detergent additives like Dex some 40 years ago.
Old Aug 20, 2009 | 03:47 PM
RowJ's Avatar
Originally Posted by 67HotRod
... I have goerend vb/tq and Dave told me to use ATF3 with the lubeguard, not the ATF4.
That works for after market trannys but I would not do it on a tranny rebuilt to factory specs.
I agree with 'Dozier'. If factory rebuild .... use ATF+4.
I prefer it in my DTT as well, but the reasons why do not concern this thread.
RJ
Old Aug 20, 2009 | 04:19 PM
mttjma2002's Avatar
well im having the TC popping out in 3rd and 4th at lower rpms which is noise,wiring or something else. However when it locks and does pop out im having the shutter and its shaking the truck a little bit.
Old Aug 20, 2009 | 05:58 PM
Classic TC cycling. Use a DTT noise filter.
Dave
Old Aug 20, 2009 | 10:33 PM
67HotRod's Avatar
RJ
They didn't have ATF4 in 2002 correct? Factory specs would be ATF3, so dex with lubeguard is the closest to ATF3. Just asking.
Old Aug 20, 2009 | 11:28 PM
mttjma2002's Avatar
yeah im about to A. get a noise filter and B. get some lubeguard.
Old Aug 21, 2009 | 12:22 AM
'02s had ATF+4.
Dave
Old Aug 21, 2009 | 12:24 AM
67HotRod's Avatar
Originally Posted by Fishin2Deep4U
'02s had ATF+4.
Dave
Thanks, I thought they switch in 03' to ATF4.
trust
21
Jul 1, 2012 11:01 PM
Hicksy
20
Dec 29, 2007 03:14 AM
RobG
Aug 18, 2005 01:22 PM
ZS
Jun 25, 2004 04:28 PM
