does not move anymore
Was climbing a good size hill right out of town with empty snowmobile trailer with tst on 5 and floored it and a bang. Now there is no movement in 2 wheel 4 wheel nothing i am thinking either input shaft or destroyed another valair. It does not make any noise in any gear. Wont have anytime to look at until sunday.
Yea, sounds like an input shaft to me. If it broke it wouldn't make much noise. If there's no change in sound when you take it out of gear or put it in gear it would make sense for the input shaft on the trans to be your culprit.
No, it's not too common but when you're throwing power down, like floored w/ a box on 5x5, up a decent grade, especially with any extra weight behind you...well, bad things can happen. I'll be impressed if he did break the input shaft. If I were JD4440, I'd put the sucker on a mantle in my garage.
trans
so got it apart and sure enough input shaft is in 2 now what i am try to see if i have enough money for dual disk and input shaft maybe i can start pullin again i will see
Smkn600CTD
Jan 22, 2007 03:29 PM
mhuppertz
Dec 31, 2006 07:59 PM
lezmark7
Feb 26, 2005 01:38 PM
Battering Ram
30
Feb 12, 2004 11:23 AM
