does any body have the same problem i do?
Old Jan 14, 2008 | 09:49 PM
psd tuner's Avatar
i would think a engine with 100K would have oil leaks as bad as mine. my rear main seal and some seal infront of the motor is leaking oil. The entire front of my engine is oily all the trans lines is covered with motor oil and the entire oil pan is leaking. This thing is like a Detroit...oil every where. heck i had a 5.0L ford f-150 before this truck and the rear main seal didnt start leaking till 180,000 and it barely leaked. mine drips perdy good, just woundering if any body has the same problem as me...just curious i know this is kinda a stupid question because every vehicle has different problems.
Old Jan 14, 2008 | 11:08 PM
chainzaw's Avatar
Hey bro check this. It may be your puck bottle that needs to be emptied or BOMB. https://www.dieseltruckresource.com/...d.php?t=182688 Let us know what you find.
Old Jan 14, 2008 | 11:17 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Yeah, I'll bet that your breather/puke bottle is just full.
Old Jan 14, 2008 | 11:21 PM
dozer12216's Avatar
If it's not the crancase vent, you may have to clean engine and use engine oil leak dye to find. Dealer should have info on procedure.
Old Jan 15, 2008 | 12:06 AM
Tate's Avatar
Also check the valve cover gasket. That might be leaking, and the oil will run down the back of the engine. I also have the turbo oil drain leaking on mine, right where the steel tube and rubber joint in the block. Everything above that is dry, everything below it is sopping wet.
Old Jan 15, 2008 | 07:40 AM
J Lent's Avatar
Good point Tate! I had a oil leak that I thought was the oil pan, turned out to be the valve cover gasket. Make sure to change the little bolt seals in the top of the cover also.
Old Jan 15, 2008 | 06:54 PM
psd tuner's Avatar
i didnt know it had a crank case vent, i seen somthing like what yall are talking about, will look thanks for the great info. i just got this truck in sept. and dont know much about them but i am learning.
Old Jan 15, 2008 | 07:04 PM
J Lent's Avatar
Check on the front of the engine on the drivers side. That is your problem, these vents blow alot of oil out if you run it hard.
Old Jan 16, 2008 | 10:32 PM
psd tuner's Avatar
yeah the stupid bottle was filled with water and oil...i cured that problem. i took the oem hose off the bottle, screwed in a 1/2" nipple and took a peice of 3/4" seal tite (flexible electrical conduit) and screwed it in to the nipple. took 2 hose clamps and tightened the hoses up. ran the peice down the front of the motor and zip tied it to the sway bar.
Old Jan 16, 2008 | 10:42 PM
chainzaw's Avatar
Cool, I'm glad that took care of your problem.
This site is the BEST place to learn things about your truck! I only wish i had discovered it sooner.
J Lent
60
Nov 3, 2009 09:14 PM
wreedCTD
27
Sep 30, 2007 09:52 PM
jmccart
Jan 18, 2007 03:26 PM
jimjawz
Jan 2, 2005 12:22 PM
