Differential lube change
Old Dec 27, 2002 | 07:45 AM
Alan_Reagan's Avatar
Re:Differential lube change
Mine has worked great without the modifier for over 60,000 miles now. If I add it to make someone happy, it would probably be too much and I would lose my LSD. I'm past my warranty and even if I wasn't, I would like to see them send the used lube off and have an analysis done on it and prove it wasn't used. Before I changed my lube, I had a slight shudder on turns. Since I went to synthetic lube WITHOUT THE MODIFIER, I have no shudder and the LSD works like it is supposed to. I had exact same situation in my 98 before I went to synthetics. It all depends on the brand you use whether you need it or not.
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
markm4
Jul 29, 2007 11:16 AM
Tartarus
Jan 23, 2004 07:24 PM
bulabula
18
Oct 25, 2003 12:01 AM
